SailNet Community - View Single Post - yanmar 3gm30f 1 cylinder bad condition
post #10 of Old 08-27-2011
fryewe
fryewe's Avatar
yj, the advice to check your valve clearances and adjust if needed is a good start. You already have the cover off, so you are ready to go. Do you have the Yanmar manual for your engine? Is your engine access on top of the engine enough to allow doing the clearance check and adjustment?
fryewe is offline
