SailNet Community - View Single Post - Port tack faster than starboard tack, same point of sail?
post #11 of Old 08-28-2011
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Originally Posted by jrd22 View Post
Unless I'm confused the OP said he has a list to port (more weight on port side) and he consistently sails faster on a starboard tack. If weight distribution was the cause you would think that the boat would be faster on port tack because it would sail flatter (as the OP said). I would suspect rigging tension but there are a lot of unknowns to explore.
It all depends on the boat. In light winds, the port list may help to lower the wetted surface area of the hull a bit on a starboard tack. At slow boat speeds (e.g., in light winds) wetted surface area has a disproportionately large effect on overall drag.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
