SailNet Community - View Single Post - Port tack faster than starboard tack, same point of sail?
post #12 of Old 08-28-2011
jackdale
jackdale's Avatar
Originally Posted by jrd22 View Post
Unless I'm confused the OP said he has a list to port (more weight on port side) and he consistently sails faster on a starboard tack. If weight distribution was the cause you would think that the boat would be faster on port tack because it would sail flatter (as the OP said). I would suspect rigging tension but there are a lot of unknowns to explore.
John you are correct. I had a visualization problem. A port list would make a port tack faster.
jackdale is online now
