The "squeak" frequently comes from the strands of line rubbing against one another as they stretch and retract. The process generates internal friction that heats the line up, causes the strands to expand slightly, increases the friction, etc. etc. etc. Several research studies that line failures are frequently caused by internal heating rather than chafe, particularly when lines are run through plastic tubing that prevents water getting to the line and acting as a coolant.
When line is manufactured, it is given a coating that serves as a lubricant. As the line ages, however, the coating is washed away, particularly so if it's actually washed although that is sometimes necessary to remove sand and salt crystals that themselves are abrasives that will abrade or chafe a line internally. While most do not like moldy lines--in fact, the mold is slippery does tend to mitigate chafe. But who likes handling green "slimy" lines eh?
One cure that is somewhat more long-lasting is to clean and dry the lines and, once dry, give them a good dose of SailKote to somewhat restore the lubricity lost in the cleaning. A "squeaking" line is wearing out.
FWIW...
