SailNet Community - View Single Post - Starting a diesel that sat for 18 years.
post #9 of Old 09-02-2011
wescarroll
I would as you say drain the entire fuel system and discard the fuel. Change all filters crank oil, and trans oil. Fill the fuel tank with bio diesel, it has a higher lubricity than petroleum diesel, coat the raw water impeller with petroleum jelly and reassemble the pump and shut off the raw water until it starts running. Remove the intake silencer and fog with fogging oil for a couple of cranks decompressed, bleed fuel system according to mfr's instructions and start her up. If you can turn the crank pulley it is either not locked up or it is in need of an awful lot of work as something big would have to be broken(given what you have said about hours I think this is unlikely). I wouldn't pull any injectors until I have exhausted the fuel supply side, as if you have fuel, timing and crank a diesel will run unless something big is wrong.
wescarroll is offline
