SailNet Community - View Single Post - Changing Oil
Thread: Changing Oil
post #8 of Old 09-03-2011
centaursailor
Senior in age only!!!
centaursailor's Avatar
I use a small brass hand pump available in most chandlers. The hose, about 3/8in was just too tight for the dip stick hole so I found a 18in length of 1/4in od copper pipe that pushes into the hose. Its is a bit of waste fridge copper, but it could be any pipe or smaller hose that fits into the original pump hose.
I also use the pump to transferrer diesel from my reserve barrel to the tank when at sea, saves a lot of spills in rough weather so I don,t feel guilty about poisoning the sea.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
