SailNet Community - View Single Post - Advice, please on crimping wire connections...
post #46 of Old 08-23-2006
sailingdog
Originally Posted by happyman
Shrink tube can be slid over the wire and warmed up with a heat gun, or better yet, shrink connectors can be purchased to give the same results -> a water tight seal.
Good luck!
Only adhesive-lined heat shrink tubing really gives a water tight seal. Normal heat shrink tubing gives a seal, but is not water-tight as capiliary action will wick water up in to the tubing.
And Jorjo... that just mean's you're an Irish illiterate @$$.
sailingdog is offline
