SailNet Community - View Single Post - Lead ballast bolts
post #2 of Old 08-23-2006
sailingdog
Couldn't you use galvanized steel bolts instead.
They have been used on a fair number of production boats with a fairly decent record. They are considerably stronger and cheaper than the copper bolts would be, if you could even find copper bolts.
If you're using stainless steel bolts, you'd be best off using 316 rather than 304 stainless as 304 stainless has some issues in a low-oxygen high-chloride ion situation that can cause premature failure.
sailingdog is offline
