SailNet Community - View Single Post - How to fly spinnaker faster
post #5 of Old 08-23-2006
sailingdog
While it might not be as important if a Spinnaker loses some shape, at least compared to other sails, the sail's material can age quite a bit and then becomes fairly porous, letting a lot of the wind it is supposed to be capturing through.
That sounds like what may be happening in your case. Even if the sail is properly shaped, if the material is so uv-damaged and the cloth has lost its ability to hold air pressure, then it will not be an effective sail.
sailingdog is offline
