SailNet Community - View Single Post - Catalina 22 - Seized Rudder Casting
post #1 of Old 09-07-2011 Thread Starter
dRabbit
I recently purchased a 1984 Catalina 22. The boat was in great shape for a salt water boat. The only thing I had to do was clean off the barnacles and paint the bottom to get in useable condition. Everything else was clean, clean, clean. That's where I need some help.
Basically I have taken everything off clean it and put it back. (Yes I used marine sealer). The problem I'm having is with the rudder casting. Having a salt water history I wanted to take the rudder casting apart and clean it but I can't get it apart. I had to take a thin putty knife and dig the salt residue from under the rudder lock disc to get it off. The salt was so hard it took hours to accomplish this otherwise simple task. The rudder casting is a whole new problem.
I have tried everything I know to get the rudder casting apart except cutting the heads off the screws and hoping I will be able to drill and remove the screws with and easy out. I am reluctant to do this without asking for opinions from owners who have faced this same problem. If you have dealt with this problem before and have any suggestions I would be most grateful.
dRabbit
dRabbit is offline
