SailNet Community - View Single Post - When to raise mainsail on 26 foot S2
post #7 of Old 09-09-2011
jackdale
jackdale's Avatar
Originally Posted by PJFORD View Post
I always choose the main; better control (you can "back" it if needed), and generally the main will not hoist well off the wind so heading-up leaves you with a flogging genny/jib while you raise the main . Also setting the jib/genoa to get the best "slot" is better done after setting the main. I've had to sail into a busy marina under sail alone after a minor engine failure and i wouldn't attempt it with a headsail alone, just not enough control.
A month ago I had to sail to the government dock in Port Hardy. Did it under the main only.
jackdale is offline
