SailNet Community - View Single Post - Low Maintenance Brightwork: Varnish or Linear Polyurethane over Epoxy?
post #8 of Old 09-14-2011
deniseO30
One of None
deniseO30's Avatar
Epoxy on teak will lift eventually, The heat from the sun will cause oils and moisture to try and escape. Also if the epoxy is only to the edge the edge of the epoxy will eventually lift.
Cetol is a good choice but most all outdoor bright work will need regular maintenance unless you let it go gray/silver
My last project!
deniseO30 is offline
