SailNet Community - View Single Post - Low Maintenance Brightwork: Varnish or Linear Polyurethane over Epoxy?
post #9 of Old 09-14-2011
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Originally Posted by sailingfool View Post
You should definatitely go with the Cetol. If you use epoxy/varnish, some day when you or a subsequent owner has to remove it all, you will wish you hand't used it. The magic of Cetal is that it is not hard to remove, when you need to start over.
We switched to Cetol Natural Teak last year and have been very happy with the results. I used 3-coats of Cetol Clear over two of the Natural Teak after completely stripping the old finish to bare wood. At this point I only have to add a coat of clear at about 6 month intervals which is easily done. One merely "scuffs" the existing finish with a Sctochbright pad, wipes it down with 90% alcohol and adds the Clear. For those farther north, I suspect the interval for re-coating would be less.
FWIW...
svHyLyte is offline
