SailNet Community - View Single Post - Need a new fuel tank
post #20 of Old 09-14-2011
apogee1mars
apogee1mars's Avatar
The tank can be repaired using the same technique as used in the fabrication of the Vans RV series aircraft. You could even cut an inspection hole in the tank to make sure you are doing all of the corroded areas. Not that tough. Just some sheet aluminum, rivets and sealant will do the job. Not to mention the grunt work of R&R.
apogee1mars is offline
