SailNet Community - View Single Post - portable anchor light
post #9 of Old 08-25-2006
sailingdog
Yes, but you would think that if the MegaLight was USCG compliant for use as an anchor light, they would say so on their sight.
I would also refer you to the following story.
The Mega-Light actually comes in three versions. The original model, now called a "Utility," has no provision for mounting. The identical light with an L-shaped stainless steel bracket and a 12-inch pigtail for wiring directly into the ship’s power instead of a portable cord is named the "Masthead." Although Davis claims a two-mile visibility, which would be legal as an anchor light on most vessels, the Mega-Light is nowhere near as bright as a standard anchor light. We have a Masthead model mounted in the interior as a security light at our stairway with a switch to turn it off when it is not wanted.
sailingdog is offline
