SailNet Community - View Single Post - Starting a diesel that sat for 18 years.
post #31 of Old 09-19-2011
casey1999
casey1999's Avatar
Originally Posted by xymotic View Post
Start with the easy/obvious. Disconnect the throttle at the engine and see if manually moving the lever you can get full RPM. Could just be an adjustment of the cable.
I have done this. The throttle control at the engine is at the maximum postition, and engine still below max rpm.
I would think the engine should always have some return fuel no matter what the throttle position, but maybe I am wrong. I do not have a good understanding the relationship between the injector pump and the fuel injectors.
casey1999 is offline
