SailNet Community - View Single Post - Battery Fuse Sizing - How, What...?
post #28 of Old 09-21-2011 Thread Starter
Maine Sail
Maine Sail's Avatar
Originally Posted by josrulz View Post
Do you mind me asking--where did you put the POS bus? Is it opposite? That looks like a tight spot on our boat.
Water heater compartment works well.. Just drill the wires through the bulkhead.
I'm thinking of putting the MRBF fuses on the bus bar, only because the clearance above the batteries is tight. They appear to fit, but they are very close.
With some batts they will clear but with most they won't. The buss bar is fine joust route the POS into the water heater compartment.
Second, the POS studs on my batteries are 5/16, not 3/8. Is this going to be an issue with the MRBFs since they're made to mount on 3/8 studs?
Thanks!
-J
Many are and Blue Seas does not make a 5/16" MRBF, been round and round with their engineering department on this.
Blue Seas says it is perfectly safe and "acceptable" if your post has a wide enough base to use a 3/8" on a 5/16" stud.. Personally I would rather see a 5/16" MRBF but they simply don't exist..
______
-Maine Sail / CS-36T
Maine Sail is offline
