SailNet Community - View Single Post - Changing Oil
Thread: Changing Oil
post #17 of Old 09-22-2011
tommays
tommays's Avatar
The Oil comes right out if it is warm as i use the same pump on inboards that suck up the oil through the dip stick the 3/8 NPT hole will take a 3/8 metal tube which allows a lot of oil to pass
That is the new Moyer pump with the quick change cover and i used two ball valves on it as i do not wish to drain the FWC anti-freeze every time i need to change the inpeller
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
