SailNet Community - View Single Post - Raising the sails without the motor
post #8 of Old 09-23-2011
overbored
overbored's Avatar
Originally Posted by Hartley18 View Post
Whilst that may be great for you - it doesn't work if you don't have an engine to leave running..
David,
Raising sails: Your plan is as good as any I've come across and, yes, the key is to be able to get the sails up and down without too much struggle. Certainly the only way to do it is pointing into the wind. Some boats (like mine!) will allow you to do the following:
1. Unfurl the genny, get some way up on a close reach.
2. Heave to (ie. tack without touching the sheet, helm down)
3. Hoist the main
4. When ready, tack the headsail and sail off into the sunset...
Lowering sails: Same as coming into the dock under sail.
1. Drop one sail whilst sailing close to the wind on the other.
2. Get the other one ready to drop (lines clear, etc.)
3. Drop the other sail in a rush when needed.
It's valuable experience and worth practising!
Sounds easy but you left out the part where you got away from the dock. How did you get from the dock to open water where you have space to unfurl and sail off into the sunset. How do you do this from a windward facing side tie in 15 kts breeze.
"GOLD RUSH" PRINDLE 16
overbored is online now
