SailNet Community - View Single Post - Low buck projects- Let's see 'em!
post #267 of Old 09-25-2011
Faster
Ray... hereabouts Home Depot and other hardware stores often stock screening kits.. the screening, straight pieces of extrusion which you cut to size and then corner pieces that insert. The screen is then placed over the frame and an o-ring type material pressed into the extrusion to hold it in.. Sounds like StormBay had to trim the rather square corners to fit.. it's a good looking result, isn't it?
Faster is online now
