SailNet Community - View Single Post - Splicing problem
post #27 of Old 09-28-2011
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Originally Posted by Zanshin View Post
Some ropes are tougher to splice than others, and a doublebraided line that has already been used or put under load can be almost impossible to splice. I found that my big rubber mallet helps a lot, I "tenderize" my line for a bit and then get another millimeter before repeating the process. I have a very thin steel fid to pull the line through, it is thinner than Brion Toss' magic wand and I also thin the core down before pulling it.
Do you know which brand line you are splicing?
I've found that washing the lines in a washing machine will sometimes soften them enough but basically, as Zanshin says, old double braid is not a good bet.
SloopJonB is offline
