SailNet Community - View Single Post - Shroud tension
Thread: Shroud tension
post #8 of Old 08-28-2006
sailingdog
You've broken an ear off the chainplate. You're going to have to replace the chainplates...and while you're at it, you should replace the ones on the otehr side and inspect the ones at the bow and stern for the forestay and backstay respectively. I would also recommend you check the masthead fittings for the stays and shrouds... it sounds like your boat has a bit of a corrosion problem.
BTW, welding one isn't always a good choice, as the welds tend to corrode faster than a new, machined chainplate would. The problem with the welds is that the carbon ties up the chromium in the stainless steel, and that prevents the stainless steel from passivating properly and it rusts fairly quickly.
BTW, I'd be wary of saying the cable and turnbuckle are fine until someone inspects them thouroughly.
sailingdog is offline
