SailNet Community - View Single Post - Shroud tension
Thread: Shroud tension
post #11 of Old 08-28-2006 Thread Starter
ktucker8
Also welding the chainplate- The welded part once installed is below deck and the top sealed with a sealant to keep water from getting down into the deck. Do you still think It would cause a corrosion problem for thy are welded at the Factory? It is being welded with stainless. Just trying to figure out where I would get custom chainplates made without welding. Thanks Ken
ktucker8 is offline
