SailNet Community - View Single Post - In order to bareboat charter...
post #7 of Old 10-03-2011
Donna_F
The most female moderator
Donna_F's Avatar
Dock
Originally Posted by Ninefingers View Post
Although here's a question. And this will surely wrinkle a few feathers, lol! I have only used a furling main. How hard will it be to learn to raise and reef a traditional sail? From the looks of it, most charter boats have traditional mains.
The hardest part I've found is completely lowering the main underway and folding it down on top of the boom.
Center the main. Heading into the wind helps so that the main flutters and the tension is released. Have the helmsman put the boat in neutral or if you must go forward, go as slowly as possible. The helmsman should keep a lookout and alert whoever is lowering the main to any approaching wakes so he or she isn't knocked off balance and if the boat has to turn into a large wake (which means the wind will fill in the sail). When going on deck, don't forget the sail ties. If just reefing the sail this will be when you tie the reefing lines (if equipped) rather than take it all the way down. Some boats are equipped with a hook that attaches to the leading edge of the sail to keep it in position while you tie the lines.
It's easier to reef the main before raising it completely. If you know that the wind is strong before leaving the mooring/anchorage/dock, tie the reefing lines before you leave.
Donna
Catalina 30 TRBS
Rock Hall, MD
KB3ZCB
Donna_F is offline
