SailNet Community - View Single Post - Keel Question
Thread: Keel Question
post #1 of Old 10-03-2011 Thread Starter
pirateofcapeann
pirateofcapeann's Avatar
Keel Question
I just went in halves on a Northstar 1000. Problem is that there is quite a gap between the lead fin keel ballast and the hull. The keel-bolts and hardware look to be stainless steel. I have a plan but need some answers before I can proceed:
1) Are the keel-bolts tapped or molded into the lead only or is there a carrying plate molded in there to carry the load?
2) The bolts look to be ĺ-inch. Not knowing what they are tapped into, I have no idea what my starting torque value on the keel nuts should be. I donít want to risk pulling the bolts out of the soft lead by over-torquing. Suggestions?
3) Iím leaning toward using 5200 to re-bed the keel as I had good luck with that on another boat some years ago. Anyone got any other thoughts?
Thank you in advance!
________________________#\__
"Who would go to sea for pleasure
would go to hell for pastime."
PoCA
pirateofcapeann is offline
