SailNet Community - View Single Post - Cooling water - to screen or not to screen?
post #3 of Old 10-05-2011
BELLATRIX1965
Maine Member
BELLATRIX1965's Avatar
Don't do it!!!
Originally Posted by hellosailor View Post
They're all true.
Now, would you rather use neverseize on the screws and clean that fitting out once or twice a season, or try to unravel plastic bags from your water pump?
Firstly, I believe the "anti foul" comment referred to not being able to coat the INSIDE of the suction strainer against marine growth - which IS a concern, not frozen fasteners.
About a year or so ago, there was quite a thread on the "gear and maintenance" board about this very issue. Some very wise sailors (Mainesail among them) pointed out that if you have a screen on the outside of the hull, you cannot take the hose off and run a clean-out rod through the fitting from inside to outside (yeah, you will get a little wet!). You presumably have a suction strainer before your raw water pump, so it has plenty of protection. If you pick up a big plastic bag or something similar on the outside of the hull, the external suction screen will get clogged just as much as a simple through-hull opening will. Only difference is: you CAN'T rod out the through-hull from the inside with a suction screen blocking the passage on the outside!
After reading that past thread and giving this some thought, I removed my suction strainer on the outside of the hull. No problems to this point (knock wood!). Anyway, DON'T DO IT!!
BELLATRIX1965 is offline
