SailNet Community - View Single Post - pearson 26 new owner
post #18 of Old 10-07-2011
fendertweed
Originally Posted by beaufait View Post
I didn't try to remove the nuts normally. I picked up a nut breaker and a chisel from Harbor freight for about ten bucks and cut the nuts off. Many were so corroded that simply hitting with a hammer caused them to disintegrate. The bolts were actually in pretty good shape. The nuts were exposed to fresh water from leaks around the windows. (My next big project) I felt that stainless was a better choice in the bilge. After looking at the posts here it was stainless or bronze and I didn't have the money or the time to get the bronze. These should last for the life of the boat. (I hope!)
Good Luck
joe
How did you brace/hold the keel while you did this work? Did you do a bolt at a time to keep the others in place to hold it, or did you build some kind of frame such as Dan Pfeiffer illustrates on his P26 site (I think)?
Thanks,
Jon
S/V Catalyst:
Pearson 26 #1200
fendertweed is offline
