SailNet Community - View Single Post - Fuel Filter and Base for W30 Westerbeke
post #3 of Old 10-08-2011 Thread Starter
Carpevelum
Originally Posted by dabnis View Post
"However....the old banjo nut is longer than the new one and has a smaller hole
in it, whereas the new banjo nut on the top is so short that we can't get the
old banjo fitting around it and have threads to screw into the filter base. The
new one also has a bigger hole in it (which is why, we're assuming, we were
having high rev issues as in our previous post). Does anyone know what banjo
fitting I need for this?"
Carp,
Can't help you with the fitting issue but I wouldn't think the flow volume through the filter would effect the high rev issue on start up. If it is not a cable or linkage problem I would suspect a high pressure pump / governor problem. As asked before, did the engine ever run properly and has there been any recent work done on it?
Dabnis
Thanks for the reply. We just checked the cables and linkage and they are fine. It is all attached and has the right "travel." The engine has run properly for the last 1.5 years we've had the boat and 200ish hours of use. The only thing we have done to the engine recently is change all the fluids and oil filter, which it worked just fine after. Then I went to change the Racor primary and the on-engine secondary filter, and once I got the new filter base and filter installed and re-primed this happened. So...I believe it to not be a random problem since it was working fine right before this.
Carpevelum is offline
