SailNet Community - View Single Post - Shroud tension
Thread: Shroud tension
post #25 of Old 08-29-2006
knothead
Originally Posted by ktucker8
Thank you for the info- I will check Latitude 38 out- Also Thanks again Saildog for the tip I am checking with the Columbia boat owners for a copy of the specs and owners manual! Ken
Don't make the mistake of assuming that measurements you get from a spec. sheet will work for your boat.
Measure or remove the wires from your boat before you remake them or have them made.
Svendsen's has a good reputation. You could pull right up to their dock for the inspection also.
knothead is offline
