SailNet Community - View Single Post - Shroud tension
Thread: Shroud tension
post #26 of Old 08-29-2006
sailingdog
Knothead has a good point. Your boat may have been altered a bit from the standard setup, so the rig may or may not be the same length as the specifications. I've seen masts that were longer or shorter than the original put on a boat....and given the age of your boat, a lot could have happened to change the rigging measurements.
sailingdog is offline
