SailNet Community - View Single Post - Shroud tension
Thread: Shroud tension
post #27 of Old 08-29-2006 Thread Starter
ktucker8
Well I was going to remove the chain plates one at a time?And check them for corrosion then buy cable and new hardware with the proper crimping tool and cut and replace each cable the same length as the old one ,one at a time. I wasn't sure if I could remove all the shroud lines at the same time even being dockside if that was wise and being a Columbia my mast does not run through the cabin to the keel.
ktucker8 is offline
