SailNet Community - View Single Post - Catalina Keel bolts
post #3 of Old 08-30-2006
sailingfool
ASA and PSIA Instructor
If your keel is steel you should be able to tell because it is almost certain to have rust spots on it.
Whatever you're problem, I've never heard of someone replacing a "worn" keel - it may be the one part of a boat not subject to wearing out. Get a hold of a local surveyor and find out when he/she will be in your boat area. For an hour's pay the surveyor can look at your bolts and advise on repairs - better yet, if you did not have a survey done, have the whole boat inspected - if you need encouragement for this expense, read Shroud tension
One is far more likely to have the mast come down than the keel fall off...
sailingfool is offline
