SailNet Community - View Single Post - Keel Question
Thread: Keel Question
post #7 of Old 10-13-2011
ronspiker
ronspiker's Avatar
The torque for bolts is set by the Type Thread Count and Size of the bolt and if there is any coating on the bolt threads. As an example a
3/4 in SAE2 with 10 threads per inch is torqued to 157 ft lbs if oiled it is 121 ft lbs, if coated with teflon it is 50% less than that..
Check the following website for guidelines. BOLTS AND TORQUE SPECS
ronspiker is offline
