I am a new owner of a 1978 Islander 28 and have a compression post issue as well. The other threads indicate removing the existing post and replacing/shimming the bottom end to restore the correct height. Looking in the head, there appears to be a post in the corner of the bulkhead and inner cabin wall. Is that what has to be removed? When lifting the floor bilge boards I can see a plywood plate on top of the stringers but do not see any distortion or collapsing. The oak shelf above the table has cracked and distorted due to the compression loads and I would like to restore it if not too difficult. Any suggestions?
