SailNet Community - View Single Post - Shroud Tension Update
post #4 of Old 08-30-2006
sailingdog
It might also be worth taking the screws out of the mast fittings, and coating them with anhydrous lanolin or Lanocote, and putting them back. This will help to help prevent galvanic corrosion from occurring.
If you find any areas with a lot of white powdery material..that is probably someplace that you've got a galvanic corrosion problem, and it should be cleaned and investigated further.
sailingdog is offline
