SailNet Community - View Single Post - How much zinc is enough?
post #7 of Old 10-15-2011
boatpoker
Dirt Free
boatpoker's Avatar
Many people in the Marina also hang a clamp on "Grouper" zinc anode due to stray currents causing galvanic corrosion.
Stray current does not cause galvanic corrosion. Stray current corrosion and galvanic corrosion are two entirely different things.
Yeah, you can over do it with anodes. They will react with the copper in the bottom paint. Foggy
From what I've read it is possible to over do it with zincs. There has to be the correct amount of sacrificial anode to neutralize electrolysis. Too much will create current where it didn't exist before.
You cannot "over do it with anodes" No matter how many anodes you affix (if they are all of a kind) the voltage potential does not change. You can only over protect by using improper anodes (zinc, aluminum-indium, magnesium etc.) for the water the boat is in.
Electrolysis has nothing to do with it. Electrolysis is a chemical change in an electrolyte due to the passage of current.
Simple physics ..... there can be no electrolytic reaction without contact and anodes should not be in contact with bottom paint.
They work although there are better methods to bond the shafts such as something like a wire brush or even a carbon electrode.
A carbon electrode will most certainly cause galvanic corrosion in stainless steel.
Petar : There is more mythology on this topic than anything else in boating and it an extremely complex issue. Either hire an ABYC Certified Corrosion Technologist or take the corrosion course yourself but take all dock walker advice with a grain of salt.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
