SailNet Community - View Single Post - '84 Hunter 31 Close Hauling
post #9 of Old 10-16-2011
eMaddog
Apologies for adding this comment late. I owned an 84 Hunter 31 for several years in the early 90's and got to love it. It's a very dynamic boat and easy to overpower. Inefficient pointing is often a symptom of just this. In addition to Davidpm's excellent comments, I would add a couple of things: one, your headsail trim, a couple of points here, both involving playing around with snatch blocks. If you have a furling genoa, unless it's a new system you'll have luff shape problems when you reef, and that of course will make you hesitant to reduce sail, but there is a way to address that without buying a new furler. A sail maker can place grommets in the genoa foot which you can use to haul down the foot. Also, a light line can be clipped on to the clew, run center-aft as a Barber hauler (not to be over-used - keep an eye on the main to make sure you're not creating turbulance in the slot). Second, you've got to make sure the standing rig is tuned well. A lot of riggers don't understand the B&R rig and are hesitant to stiffen it properly - the shrouds and stays need to be tuned as if they were a musical instrument. Tuned and trimmed right your Hunter will be a rocket ship. What a great boat.
eMaddog is offline
