SailNet Community - View Single Post - '84 Hunter 31 Close Hauling
post #10 of Old 10-16-2011
SHNOOL
4KSB driver.
SHNOOL's Avatar
Sail SHAPE is probably the deal here... all of the above advice is sound, however, if you do it all perfectly, if the sails don't have the proper curve you can't pull over 45 degrees off wind.
I noted this when I got this capri (110 furler). I wound up purchasing a 2nd hand 155 mylar and my point came up nicely. Then I found the original number 110 jib as a 2nd hand replacement, and it also got me nearly there. So you may be doing everything correctly but if the sails aren't up to it, you may be stuck.
Furlers are designed for "ease of use" and convenience for cruising, so point and shape are LESS design criteria.
Another thing they tell you to do, is fall off, accelerate, then "pinch" the wind, if you trim in as you do it, you may be able to maintain speed, and grab that last 5-10 degrees.
SHNOOL is offline
