SailNet Community - View Single Post - Help upgrading A/C needed
post #2 of Old 10-21-2011
kd3pc
kd3pc's Avatar
no inexpensive way to easily use both...you will need to wire the boat one way and then adapt the "shore" power to it. That can be as easy as a transformer and some cables, or as difficult as a multi-input system and autotransformers.
The smaller capacity system, the easier (cheaper) it will be to do it. If all you want is a small charger and an outlet, you may be able to get by with a EU cable and transformer...else you would need to rewire or adapt your current shorepower..
kd3pc is offline
