A DC-to-DC adapter would be a lot more efficient than the DC-AC-DC cycle you're using now. Also, look at the power saving features on your laptop. You should be able to dim the screen; turn off the devices you're not using, either in the bios or disable them in the OS—like wifi cards, bluetooth adapters, network adapters, etc; sleep the harddrive, etc. That should lower power consumption quite a bit too.
