Originally Posted by imagine2frolic
I was going to sugggest sailing north from Panama, and then following the stream around to the Bahamas. Then folow the thornless passage. i2f
You’re correct....there is a third route as you described. And a variation on that is, having arrived in Florida, to run up the SE coast to Beaufort, NC and then sail direct to the VI or Puerto Rico and then across the Carib. to the ABCs. This involves less windward work, but you don’t see as much along the way (e.g. Bahamas, DR,
PR, etc).
