Old 09-01-2006
camaraderie's Avatar
camaraderie camaraderie is offline
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Usually what you are describing is caused by a blocked air vent line. this can happen when the VENT line has sags in it that can hold fuel in place effectively blocking the line. Wasp nests also can clog the air outlet producinng the same effect. Suggest you insure a completely straight, clear and slightly DOWNHILL run from vent to tank before looking for more exotic causes!
