SailNet Community - View Single Post - Mold
Thread: Mold
post #18 of Old 10-30-2011
wooden
Prevention is better than cure, I have lived wooden boats for years and the last thing I want is any mold of any type, the way I combat it is ventilation when ever it has been raining, as soon as it stops I open all vents,ports,hatches,ect but leave the heating going on low, this helps lift the warm damp air out of the boat and drys it out well.
A electric fan heater is a great form of dry heat
If you have oil lamps don't use them when the boat is shut up Kerosine, gives of a lot of water vapor when it is burned, also if you I don't know how you cook or heat the boat, but Propane also gives of water vapor.
When you are not on the boat, vent it as much as you can, as temp changes between the outside of the boat and the warm air stuck inside the boat it will condensate, and provide a great home for the mold
I find Lysol great for mold
Hope this helps
wooden is offline
