Old 10-30-2011
estaban estaban is offline
estaban is on a distinguished road
Hi Estaban,
If you really insist and if they see that you would not buy the boat without stability data the factory will provide you with a stability curve made by the boat designer and used to certify the boat.
Good to know, thank you!
If you use a RM curve you can calculate all those values.
Yes, if having the curve. I was trying to think of ways to have a limited set of numbers to compare with. Agreed that the curve itself will always have more information.
About the resistance to heel at 0º I don't understand what you mean. You have to explain that better. At 0º the boat is not heeled .
I wrote it horribly, not according to what I was thinking. I was thinking of the derivative, the rate that stability increases from zero degrees: the slope of the curve. In other words, does stability increase only slowly as the boat begins heeling from zero degrees, or sharply? A single number could give a reasonably good picture here.
