SailNet Community - View Single Post - LPG plumbing - teflon tape?
post #1 of Old 11-01-2011 Thread Starter
MarkSF
The day is nearly here to re-commission the LPG system.
I have new tanks that aren't rusted out, a new Trident regulator with pressure gauges for leak checking, the locker has been painted inside with bilgekote, and I have a new solenoid valve / leak detector unit.
The valve will go in the locker just after the regulator, and the leak detector sensor will go in the bilge.
There's an existing pre-made hose to the locker which I'm going to re-use.
So all I need to do is fit the solenoid valve to the regulator, and the hose to the valve. Is teflon tape still the thing? I ask because I've heard of better liquid sealants that set.
MarkSF is offline
