SailNet Community - View Single Post - Old Keel bolt repair
post #26 of Old 11-01-2011
mitiempo
mitiempo's Avatar
As far as the builder doing it the wrong way, I was referring to plywood in the keel stub. When it gets wet - not if - it rots and the bolts sink into it causing the keel/hull joint to open.
Most major builders use stainless for keel bolts and if inspected every so often they are ok.
Brian
mitiempo is offline
