SailNet Community - View Single Post - Replacing the hose between the propeller shaft stuffing box and shaft log tube
post #8 of Old 11-01-2011
Tim R.
Tim R.'s Avatar
James, the shaft on a P28-1 is offset so it will clear the rudder once the prop is removed.
And dropping the rudder on this boat is very easy if you have to.
Also, if the boat has the A4, it will be a good time to repack the grease cup on the raw water pump and change the impeller.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
