SailNet Community - View Single Post - Old Keel bolt repair
post #31 of Old 11-01-2011
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Originally Posted by alanr77 View Post
HelloS: Catalina direct is now selling a "kit"..albeit a high priced one that requires only a hand drill. I can't see how this could drill a straight hole however without building a guide. I may create a homemade "press" to attach my drill to.
Just drill through a block of wood first, preferably in a drill press, then clamp it down so the hole is over the spot you want to drill. By the time your drill has bottomed out on the block the hole will be deep enough in the keel to keep things straight after removing the block.
Clamping it down is usually the easier said than done part of this procedure.
SloopJonB is offline
