SailNet Community - View Single Post - Question about mainsail troubles.
post #5 of Old 11-06-2011
mgmhead
Somewhat Senior Member
mgmhead's Avatar
Try adjusting your topping lift. Probably located on your boom, look for a line (not wire) on a horn cleat. This line will allow your boom to be lifted higher or lowered, as needed. Typically, when sailing the topping lift is loosened to permit the boom to ride as low as possible, thereby allowing use of the boom vang and mainsheet to advantage.
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
