SailNet Community - View Single Post - Blue tape hell
Thread: Blue tape hell
post #12 of Old 11-07-2011
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Originally Posted by Snboard976 View Post
Some of the tape was either scotch or 3m brand, there was some that was another brand. I believe its called painters tape. The fact that it was on a vertical surface made it difficult to soak. The varnish on much of it may have also been a confounding factor.
That's the stuff - Scotch brand IS 3M by the way. The varnish covering would certainly seal it off from the WD40.
If it happens in the future, try peeling a bit up and getting the WD under the tape, on the glue and slowly peel it away, squirting or dribbling it on as you go. I have sometimes had to work my way along like that.
SloopJonB is offline
